| Area: | ProSteel | ||
| Subarea: | N/A | ||
The Entity Coordinate System (ECS) Axes of the structural elements may be turn on and appear on placement of every structural element.
In this wiki , we will learn how to turn off the ECS axes from the ProSteel options. Follow the steps below.
1. Firstly, Hold the right click and click on the ‘ProSteel Options’
2. Now, under ProSteel Options, click on the shapes option and under options’ section, uncheck the option ‘ECS Axes’
3. This will not display any ECS axes after placing a structural element.
