| Product(s): | ProStuctures | ||
| Version(s): | CONNECT Edition, AutoCAD CONNECT | ||
| Area: | PS Options | ||
| Subarea: |
In this wiki we will see how to change the scale of the element sketch present in the model or sheet model.
Many times, there is a possibility that elements sketches appear in the small scale in the default values. So, this wiki will show you the steps to control the ‘Display Scale’ of the element sketch.
To increase size of sketches in the model you need to follow the steps below,
1. Right click and go the ProSteel options.
2. In the ProSteel options, go to the Sketch Display under the shapes options.
3. In the options for Sketch display, you can increase the Sketch length to increase sketch size in model.
4. After increasing the Sketch length value just regenerate the model and you will see the increased size of sketch display.
In this way, one can increase scale of the element sketch so that the sketch will appear properly in the model.
