| Product(s): | ProSteel | ||
| Area: | Steel Placement | ||
| Subarea: | N/A | ||
By default, the plate grid has always a less height than its plate thickness. This wiki will show you how to increase the Grid height or keep the grid height equal to plate thickness.
1. To increase the grid height of the plate, navigate to the ProSteel option by holding right click.
2. Under the options dialog, click on the options for ‘plates’
3. In here, you will observe one checkbox for Plate Grid= Plate thickness. Enabling this option will make the grid height equal to plate thickness.
4. Enable this option and turn on the grid of the plate where you will observe that grid height has become same as the plate thickness.
In this way, users can increase the height of the plate grid by enabling this option from ProSteel Options.
