| Product(s): | ProSteel | ||
| Area: | Steel Placement | ||
| Subarea: | N/A | ||
The plate gird has some default dimensions which can be changed if it is required. In this wiki, we will learn how to change the longitudinal and transverse dimensions of the of the grid.
1. To change the dimensions of grid, navigate to ProSteel Options by holding Right Click.
2. This will open ProSteel Options dialog box and in the options dialog box, click on the options for Plates.
3. In this Plate options, you will see a section as ‘Grid Dimensions’ where you can set the dimensions for grid. You can set the transverse, longitudinal spacings of the grid and height of grid. These same values will reflect in the grid of the plate.
In this way, you can alter the dimensions of the plate grid in the ProSteel options.
