| Product(s): | ProSteel | ||
| Area: | Global Settings/Options | ||
| Subarea: | Bolts, Connection | ||
| Original Author: | Sandip Kar, Bentley Technical Support Group | ||
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
When applying Web angle connection between two floor beams with the perpendicular beam, the bolting between two angles and the supporting member web takes separate bolts instead of common bolt.
1. Open Global Settings or Options dialog by holding right-click and then select Options from the context menu.
2. Now, go to the Bolts page and check on "Enable Back to Back Bolting" in Options dialog.
