|   | Product(s): | ProStructures, ProSteel |  |
|   | Version(s): | CONNECT Edition (10.XX.00.XX) |  |
|   | Area: | Global Options |  |
|   | Subarea: | Level |  |
|   | Original Author: | Jitender, Bentley Product Advantage Group |  |
 | Updated By: | Vyanktesh Nama, Bentley Product Advantage Group |  |
The 2D outline is coming out dashed in ProStructures.
To have the correct lines appear in ProStructures CONNECT Edition, please follow the below steps.
1. Open Global Settings or Options dialog by holding right-click and then select Options from the context menu.
2. Go to the Configuration / Isometric Views > Level, here we have to use number references for “Line Type” instead of text. For example, if you want to have a continuous line, you have to change the word “Continuous” to the number “0” in the Level option. See the image below:
