| Product(s): | ProStructures, ProSteel |
| Environment: | N/A |
| Area: | Profile / Objects |
| Subarea: | Display / View |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
In the model, assemblies are displayed as one part on selection.
Enter methods to resolve in this section.
1) This is to be switched off via the PS Properties of the parts.
2) Also, one can do this from the Groups tool, by the Change Group Selection command.
3) Also, you need to check off the Select Group as whole in the PS Options.
