| Product(s): | ProSteel | ||
| Area: | 2D Detail Center | ||
| Subarea: | Holes Axis Line | ||
How to change the color of center axis lines of holes in 2D Drawings?
1. Open the Global Options dialog box by Holding the right-click and then left-click on the Options.
2. Go to Configuration / Isometric Views > Level and here change the color of the Midline Level from White to the required color (here Blue). Then click on the OK button.
3. Open the 2D Detail Center and click on the Reload button.
4. Now, preview your group.
In this way, we can change the color of the center axis line of holes in the 2D Drawings.
