| Product(s): | ProSteel | ||
| Area: | Detail Center Standard | ||
| Subarea: | Insert tab | ||
This section contains the wikis related to the Insert tab of Detail Center Standard tool in ProSteel CONNECT Edition. The Insert tab is used to add detail cells to your 2D drawings.
