Please help me to make Workframe based on below grid system
| Product(s): | ProSteel/Power ProStructure |
| Version(s): | V8i / CONNECT Edition |
| Environment: | N/A |
| Area: | General Modelling |
| Subarea: | Workframe |
| Original Author | Sandip Kar, Bentley Product Advantage Group |
Prosteel generally create the Numeric and Alphabetic grids along X and Y axis (like 1,2,3...and A,B,C...etc) respectively. There is no direct option to create any Sub Grids nor to change the name of Grid Label. To create the Sub Grids follow the below steps:
1. Click on the created Workframe. The Workframe dialog box will open. Click on Text X tab. You will find Change description tool at bottom right of the box. Click on that tool, one new dialog box will open with all the levels mentioned. One can change the levels here. Follow the below snaps for better understanding.
2. Similarly it can be done for Y axis also by clicking on Text Y tab.
3. You will get the following result.
