| Product(s): | Power ProStructures | ||
| Version(s): | N/A | ||
| Area: | Setting Defaults | ||
| Original Author: | Roger Belen, Bentley Technical Support Group | ||
When using ProConcrete you would need to make sure that you have set the correct codes before you proceed with modelling ProConcrete objects.
Below is a screen shot which can guide you see where to do these settings. You can either set it as a Default or Current or even do some modifications. These applies to Rebar Codes, Concrete Codes and Mesh Codes.
