| Product(s): | ProSteel | ||
| Area: | Global Settings | ||
| Subarea: | Values | ||
This wiki will explain how to change the Subpart Grip size in the ProSteel CONNECT Edition.
1. Open the Global Settings or Options by holding the right mouse button in the View window and then click on the Options. Or search ‘Global Settings’ in the Search Ribbon and click on it to open it.
2. In the Options dialog, go to the Values page and here one can change the 2D Subpart Grip Size. Once the changes have been made then click on the OK button to save.
3. To see the effect, hold the right-click and disable subpart grip then again enable it.
In this way, we can change the Subpart Grip size from the Global Settings in ProSteel CONNECT Edition.
