DIN Duebel in the DinBolt.mdb have been changed
Height in the drawings table have been fixed
Enhanced blockname for detailing output
Angle in NC data has been fixed, if there is a straight end in the front
The display of the center lines in a detail has been fixed with the optoin hidden hole dispay axis
ProConcrete reads now the localised files
Views in detailing are now in line
Plate geometry was turned by 90 deg for NC output - fixed
Detail Center settings "display 1x" has been fixed
Most of the ProConcrete dialogs are linked to the help file
Some menu fixes
NC DXF closed the polygon with 6 vetexes instead of 5
The dimensions in the Detail center have been different to the model - fixed
RAM Elements import enabled again
Overtaking of holes has been fixed
After stretching a mirrored shape the holes have vanished - fixed
Copying of templates with the ProSteel Project command have been fixed
Some fixes in the installation
Search command is faster now
Missing holes and center lines in a manual detail - fixed
Fixes in the partlist command
Crash when switching between search templates with/without filter conditions - fixed
Crash when end plate / group dimensioning command is called for a single part - fixed
Shapes.mdb changed
Added new drawings for AutoConnect
Crash when detailing concrete parts because of empty solids - fixed
64 bit Positioning options for Concrete - fixed
Crash when previewing a workframe in some special cases - fixed
Added files into delivery for USA/Canada delivery
Shapes19.mdb in StrucLink changed
Database information retrieved from catalog was wrong
Tool tips in detail style precast pages added
Copy connections - fixed
Changes for ProStructures Plugins/.NET and ProConcrete
Bracing Tension Rod MDB didn’t work
StrucLink for Prosteel fixed / enhanced
Ribbons in AutoCAD 2010 need no longer be clicked twice
Improved retrieving complete catalog information with mdb reference
Moving member regenerated canceled baseplate connection
Missing shape references in anchor plan – fixed
X-Ref support in layout drawings – fixed
Stiffener templates in Endplates – fixed
Joist display in second preview – fixed
Angle Splice connection leaded to fatal error while importing template
Fatal error while importing SCIA Esa file – fixed
Connection CatWalk, Frame creation error when changing frame shape class – fixed
Connection CircularPlatform, Arc shape creation error when changing shape type – fixed
Connection BeamBeamClamp, Check flat file - Runtime error – fixed
Connection PurlinBeamBraceFly, ChamferX, ChamferY, Check flat file - Runtime error – fixed
Connection PipeFlange, couldn’t clone.
Connection AngleSplice - Option Overlap, Cloning, error couldn't open table
Joist database was crashing when there was an entry in joist_data_base field in joist database file
Rebar Arc segments now are displayed in shaded display
CUI Modifications / fixes
Crash in Partlist – fixed
Accuracy by factor 10 improved for bolt sizes (Washer thickness, etc. – steps now by 0.1)
Vanishing holes in stretch process – fixed
Modelspace command now working from drop down menu
Partlist option “add” was missing
Endplate connection - rotate connection – fixed
Search closest flat steel now working
Joist database didn’t read correctly
Connection BasePlate & BeamColumnBrace, - after deleting the first connection, create second one
Popup runtime error - fixed
Folder selection in Win7/Vista might fail – fixed
Wrong values for scaled Volbodies with manual set values –fixed
Bendplate Unfolding with k_value != 1 – fixed
Wrong contour line display when holes are displayed "hidden only axis“ – fixed
Added COM properties RasterDirection and DimensionDirection for Ks_ComPlate
Ps_clean_proxy exploded the position flags and bolts to the wrong location
NC Data were not correct with 2 equal cuts at one end
Filter and Order For Positioning – fixed
Crash in Handrail – fixed
Plate bending data for partlist – added
