| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.55 | ||
| Environment: | Windows 7 32 bit, Windows 7 64 bit | ||
| Area: | General | ||
| Subarea: | N/A | ||
| Original Author: | Johannes Michalowsky, Bentley Technical Support Group |
ProStructures SELECT Series 6 Update 1 Release for MicroStation and AutoCAD Version 08.11.11.55
Purpose: Quarterly Maintenance Release to address Escalation issues and Urgent issues for ProStructures SELECT Series 6
Deliverables:
List of Issues fixed in ProStructures SELECT Series 6 Update 1 Release:
Keyword |
Title |
Type |
Priority |
Detailing |
PSAC 3335: Bolt objects in preview missing |
DR |
1-Urgent |
Detailing |
PSAC 3338: 2D bolts display |
DR |
2-High |
Detailing |
PSAC 3364: Since there is no filter function for groups, 2D display of bolts is not working for groups |
DR |
1-Urgent |
Display |
Add missing command in PS for MS: color by level |
DR |
2-High |
Modeling |
Incorrect fence stretch of dynamic brace with boundary cuts/edge cuts |
FE |
ESCALATION 1339 |
ISM |
PSAC 2672: Connection tags SS5: Changing connection tag fails to update from ISM |
DR |
1-Urgent |
Modeling |
PSAC 3124: View deleted when grid as modified |
DR |
1-Urgent |
Detailing |
PSAC 3348: DC 2D Cut no Positionflags are drawn |
DR |
1-Urgent |
Positioning |
PSAC 3365: Positioning: Crash when positioning of curved reinforcement |
DR |
1-Urgent |
Modeling |
PSMS 1543: Modeling: Losing group data while copy from one file to another |
DR |
ESCALATION 1567 |
Modeling |
PCAC 488: Resizing Openings Does Not Change Rebar |
DR |
2-High |
Object Enabler |
ProSteel COE display issue in the sheet model when switching between 3D model and 2D sheet model |
DR |
1-Urgent |
ISM |
ISM: Filtering and round-tripping are broken for base plates and end plates |
DR |
1-Urgent |
Detailing |
PCMS 429: Stirrup Set labelling for DC – corrected quantities and labels for each stirrup in the set |
DR |
2-High |
Modeling |
PCMS 430: Single RebarSets ignores all polycuts in the their associated concrete |
DR |
2-High |
Modeling |
PCMS 431: Improvement - RebarSets by selected outline. |
DR |
2-High |
Modeling |
PCMS 432: Concrete Panel circular opening - Trimmer reinforcement issue |
DR |
2-High |
Modeling |
PCMS 433: Incorrect EC Reduction on rebarsets with curved or sloped outline edge |
DR |
2-High |
GUI |
PCMS 435: Select concrete button disappears in Single Rebar distribution dialog box |
DR |
1-Urgent |
Modeling |
PSAC 2666: mirrored endplate connection - holes change |
DR |
2-High |
Modeling |
PSAC 3298: weight grid plate after cut wrong |
DR |
ESCALATION 1697 |
NC Data |
PSAC 3330: NC Dxf Output wrong for Step holes or holes with depth |
DR |
1-Urgent |
Modeling |
PSAC 3357: Inserting Helix Shape Crashes System |
DR |
1-Urgent |
Detailing |
PSAC 3366: Left view Offset when Partial view is check under in Detail style |
CR |
2-High |
Modeling |
PSAC 893: new stiffener because of mirrored U-shapes |
NF |
2-High |
Modeling |
PSMS 1727: Fence strech: Workframe stretching is not as expected |
FE |
ESCALATION 1339 |
Modeling |
PSMS 2008: cut not working for some shapes |
DR |
2-High |
ISM |
PSMS 2061: ISM ss6: 'Update/Update from' ISM results in ProStructures crash with Structural Synchronizer SS5 |
DR |
1-Urgent |
Modeling |
Sloped rebarset (Generated Parallel to the current ECS) disappearing after concrete modify |
CR |
2-High |
Detailing |
PSMS 2039: after opening a different dgn file from a dynamic sheet view and go back to the original file using MS green arrow, all ProStructures objects are lost |
CR |
1-Urgent |
Other |
Batch processing for native solid creation |
NF |
1-Urgent |
Other |
Add 'ProStructures' as license option for the Layered Products |
CR |
1-Urgent |
Modeling |
Stretching does not work on copies of brace objects |
FE |
ESCALATION 1339 |
Positioning |
PSAC 3372: Can only save one posflag template |
DR |
1-Urgent |
Object Enabler |
PSMS 2107: ProSteel does not show up when X-ref in Plain MicroStation |
DR |
2-High |
Detailing |
PSAC 2679: Slothole dimensioning is displayed as "diameter x holedistance" only at the dimension line instead of "diameter x LENGTH" |
MI |
2-High |
ISM |
PSMS 2113: ISM: Cannot find metric shapes (DIN shapes HEA type) during round-tripping |
DR |
1-Urgent |
Connections |
Chinese baseplate connections |
NF |
1-Urgent |
Detailing |
PSAC 3327: Detailing Crash when doing manual 2D Cut |
DR |
1-Urgent |
Import/Export |
PSAC 3376: PS_IMPORT Staad files does not ask for correcting unknown shapes |
NF |
3-Medium |
DR = Discrepancy Report
CR = Change Request
FE = Future Enhancement
MI = Minor Improvement
NF = New Feature
