ProStructures V8i SELECTseries 6 Update 2 Release for AutoCAD Version 08.11.11.87.
Purpose: Maintenance Release to address Escalation issues and Urgent issues for ProStructures SELECT Series 6
Deliverables:
For Updates please use
Please control you License type with _Ps_license_type
For ProSteel alone (without ProConcrete) it should show
List of Issues fixed in ProStructures SELECT Series 6 Update 2 Release:
Issue ID |
Title |
Type |
Priority |
893 |
Stiffener is no longer inverted after mirroring |
NF |
1 - Urgent |
1973 |
object on "off" layer are hidden in DetailCenter view previews |
DR |
Escalation 2110 |
2003 |
NC Data Contour lines for U shapes are created clockwise direction as per NC DSTV standards |
DR |
2 - High |
2666 |
Holes in the column keep their position after mirroring |
DR |
2 - High |
2672 |
Connection tag are updated from ISM |
DR |
1 - Urgent |
2803 |
Plates that have edge modification are nolonger ignored when exporting to a DXF file |
DR |
2 - High |
2922 |
ProStructures object enabler can be installed to an AutoCAD version that is different from the version used by the installed ProStructures |
DR |
1 - Urgent |
3124 |
Manual views are not deleted after modifying the workframe |
DR |
1 - Urgent |
3154 |
Parametric stair handrail retains assigned layers |
DR |
1 - Urgent |
3174 |
Correct Total Paint Area is tallied in the Partlist |
DR |
Escalation |
3251 |
Appropriate license is activated for the AutoPlant Structural Detailer |
DR |
1 - Urgent |
3264 |
Shear plate connection is working properly in AutoCAD 2014 |
DR |
1 - Urgent |
3280 |
Splice connection updates bolts upon change in dialog |
DR |
2 - High |
3298 |
Weight is updated appropriately after cutting a grating |
DR |
1 - Urgent |
3327 |
Detail Center does not crash with manual 2D Cut |
DR |
1 - Urgent |
3329 |
Proper wide flange shape (W) name is used when exporting to PPS |
DR |
1 - Urgent |
3330 |
Correct data for step holes or holes with depth in NC DXF Output |
DR |
1 - Urgent |
3335 |
Bolt objects are included in isometric preview |
DR |
1 - Urgent |
3338 |
Bolts are displayed as 2D bolts when set to 2D bolts in the detail style |
DR |
2 - High |
3348 |
Position flags are displayed on 2D Cut |
DR |
1 - Urgent |
3355 |
Accurate bolt spacing in dynamic bracing is applied |
DR |
1 - Urgent |
3357 |
Creating Helix Shape does not crash the application |
DR |
1 - Urgent |
3360 |
User Shapes Weight is reported correctly |
DR |
1 - Urgent |
3364 |
Since there is no filter function for groups, 2D display of bolts is working as expected for groups |
DR |
1 - Urgent |
3365 |
Program no longer crashes when positioning a curved beam with irregular reinforcement |
DR |
1 - Urgent |
3366 |
Left view is created at the right location when Partial view is checked in the Detail style |
CR |
1 - Urgent |
3370 |
Unfolding line display options are working correctly |
DR |
1 - Urgent |
3372 |
More than one posflag template can be saved |
DR |
1 - Urgent |
3377 |
NC total number is reported correctly |
DR |
1 - Urgent |
3379 |
Modifications to a copied dynamic brace is working correctly |
DR |
Escalation 1339 |
3382 |
Stretching works correctly on copies of dynamic brace |
DR |
Escalation 1339 |
3393 |
Mounting space of bolts without nut is correct |
DR |
2 - High |
3395 |
Unfold outline arcs are detailed as true arcs |
DR |
1 - Urgent |
3401 |
Centerline of shapes in manual cut is displayed correctly |
DR |
1 - Urgent |
3405 |
manual dimension is correct when shortening |
DR |
1 - Urgent |
3406 |
Stair stringers with flat bars are correctly rotated |
DR |
1 - Urgent |
3417 |
First partlist result is always calculated correctly |
DR |
1 - Urgent |
3418 |
Back-to-back bolting no longer leads to a crash in the program |
DR |
1 - Urgent |
3419 |
Endplate to hollow plate do not lead to an additional center hole |
DR |
1 - Urgent |
3423 |
Labeling and hatching are displayed properly in 2D Cut |
DR |
2 - High |
3424 |
Plate edge count is reported correctly with chamfering |
DR |
2 - High |
3431 |
2D cut is placed at the right location |
DR |
1 - Urgent |
3436 |
first riser in standard stair is created in accordance to specified value |
DR |
1 - Urgent |
3443 |
Position number is retained with group copy |
DR |
2 - High |
3449 |
Vertical plate is created at the correct location after SDNF export |
DR |
Escalation 2110 |
3452 |
PPS sub groups count is accurate |
DR |
1 - Urgent |
3457 |
Flatsteel without groups is reported to PPS |
DR |
1 - Urgent |
3461 |
Handrail end form Type 5 is working correctly |
DR |
1 - Urgent |
3468 |
Back-to-Back bolting is working correctly |
DR |
1 - Urgent |
3480 |
Handrail does not disappear after update |
DR |
1 - Urgent |
3487 |
PSB export is working with Power ProStructure product |
DR |
Escalation 2950 |
3512 |
Positioning can be sorted by plate thickness |
DR |
2 - High |
3514 |
Localised folder can use a network drive |
DR |
1 - Urgent |
3518 |
Don't scale part' option is working correctly for primitive objects with user dimension points |
MI |
1 - Urgent |
3519 |
Rectangular plates are stretched correctly using corners |
DR |
2 - High |
3542 |
Equal part detection can distinguish the direction of countersunk holes |
DR |
1 - Urgent |
3562 |
Shapes no longer rotates when using grips |
DR |
1 - Urgent |
3563 |
Part label template is maintaining orientation correctly |
DR |
Escalation 2909 |
3564 |
Text Label is placed on Ps_Text Layer/Level |
DR |
1 - Urgent |
3569 |
Detail Center Express no longer crashes the program |
DR |
1 - Urgent |
3574 |
Column Splice Connection reacts to parameter changes consistently |
DR |
2 - High |
3578 |
Punch holes are placed on shear plate when enabled |
DR |
2 - High |
3579 |
Partlist dialog is displayed after Partlist mdb creation |
DR |
1 - Urgent |
3582 |
Holes are retained after changes |
DR |
1 - Urgent |
3589 |
Bend plate inner radius overwrite is allowed |
FE |
Escalation 2969 |
3599 |
Holes appear in the correct flange(s) in SDNF export |
DR |
1 - Urgent |
3600 |
Worframes are placed properly when layer PS_Workframe is locked |
DR |
2 - High |
3603 |
Elevation flags are no longer displayed in the clipped volume of a view |
DR |
2 - High |
3605 |
Height label is displayed the Positioning dialog |
DR |
2 - High |
3606 |
Consistent weld symbol creation for shear plate connection |
DR |
1 - Urgent |
3612 |
Text line style is applied to all lines in the Text label |
DR |
2 - High |
3613 |
Bend plate with multiple flanges folds correctly |
DR |
Escalation 2969 |
3621 |
Changing the assignment in a splice connection only affects the selected part |
DR |
2 - High |
3634 |
Template is saved for endplate with stiffener |
DR |
2 - High |
3638 |
Negative step count does not crash application |
DR |
2 - High |
3641 |
Selecting a line instead of a second member in a purlin fly brace connection does not crash the program |
DR |
1 - Urgent |
3655 |
Deleting the inner rail no longer crashes the application |
DR |
2 - High |
3658 |
Improve "Remove corner from a polyplate" with flanges |
DR |
2 - High |
3659 |
Crash [NC-data]-Type a non-existing nc file name and clicking on open button leads to crash AutoCAD |
DR |
2 - High |
3662 |
CollisionDetection:-When used Collision detection tool second time, previously detected collisions (vol bodies) gets disappeared. |
DR |
2 - High |
3664 |
SS6 MatchProperties: It leads to unhandled exception when executed the below mentioned steps. |
DR |
2 - High |
3665 |
After removing corner from a polyplate with facets, the contours are drawn correctly |
DR |
2 - High |
3670 |
Plate start and end positions of facets on edges are accurate |
DR |
2 - High |
3684 |
Block Center handles correctly promoted concrete and guide lines are maintained at their original locations |
CR |
1 - Urgent |
3694 |
Plate edge numbering are reported properly |
DR |
2 - High |
3695 |
Manual Detail are working in AutoCAD 2014 |
DR |
1 - Urgent |
3696 |
Stiffeners are displayed exactly with manual 2D Cut |
DR |
1 - Urgent |
3709 |
Standard Stair rebuilds only when modifications are applied |
DR |
2 - High |
3711 |
Parts can be dragged and dropped to associate them to a Detail Style |
DR |
1 - Urgent |
3715 |
Unfolding User Shape does not lead to crash |
DR |
2 - High |
3721 |
2D cut crash does not occur when zero distance is set for cut depth |
DR |
2 - High |
3724 |
Grating plate weight is reported accurately |
DR |
2 - High |
3726 |
Application can be installed from a network folder |
DR |
1 - Urgent |
DR = Discrepancy Report
CR = Change Request
FE = Future Enhancement
MI = Minor Improvement
NF = New Feature
5 new connections:
BasePlate C1, Splice C1, ShearPlate Beam/Beam C1, Column/Beam Flange C1 and Column/Beam Web C1.
