ProSteel for MicroStation V8i SELECTseries 4 (08.11.05.42)
This release includes the following:
• Support of MicroStation V8i SELECTseries 1 and 2
• Microsoft Windows XP / Vista / 7 - 32 and 64 bit
ProSteel for MicroStation V8i SELECT series 4 enhancements:
Ø Provide missing features equivalent to the AutoCAD version
• .NET API for 3rd party development
• Connection Center (33 connections)
• Block Center
• Extended Stairs and Truss Tools
• Improved Engineering Drawings
• New installer to support multiple MicroStation versions
• ProStructures-STAAD.Pro Integration (Struclink)
Ø Enable standard MicroStation command behavior
• Event Driven Input Processing
• Keyword Input Handling
• Adopt ProSteel workflow to MicroStation
Ø Stabilize the product
• Fixed over 160 issues
• Improved speed performance
