includes Rebar2ProConcrete (Bentley Rebar functionality for dynamic views)
- Concrete and rebar Drawing Production with Dynamic Views and Hypermodeling (See also here for detailed explanation)
- Item Browser support: search-by any rebar attribute (or concrete), including custom attributes
- New bar bending schedule templates with dynamic rebar sketches and dimensions
- IFC Open and Import
- Customizable Tooltips for rebar objects
- Slab reinforcing by area reacts to changes in openings
- Slab reinforcing by area reacts to changes in the bounding shape
- Rebar objects retain their new level when changed using MicroStation command
- Fence stretch improvements for concrete shapes, rebar, and workframes
- Column offset vertical bars are now calculated correctly (cranking improvements)
- Spiral column reinforcing in Column application
- T4 shapes (diamond ties)
- Standard radius bent bars are now recognized by the shape engine
- Special shapes that contain radius legs can now be created
- New Fitcurve command: turn Bspline shaped rebar into bi-arc combinations (with tolerancing)
- Chinese concrete and rebar materials
- Chinese rebar bending shapes
- Chinese rebar data/sizes
- Five new (Chinese) connections.
- New plate platform, a tool to for plate and bolt distribution.
- DetailCenter 2D blocks can now be stored in ProjectWise, providing the flexibility to users at different locations to generate and update 2D drawings, hence the links with the 2D blocks are maintained from the same central location.
- Keyin batch process for partlist/BOM, create native drawing and native solid.
- Handrail and Stair Improvements
Available on SELECT
http://select.bentley.com/FulfillmentCenter/
