| Product(s): | ProConcrete | ||
| Area: | Export / Import | ||
| Subarea: | Attach External reference | ||
| Original Author | Sandip Kar, Bentley Product Advan |
While attaching external reference of one Concrete foundation with Column and pad Footing with Rebars, it is observed that Concrete element are not coming, only the Rebars are coming, whereas all the Lavels are turned on.
While attaching please note that live nesting is selected or not. Also the nesting depth should be kept as 99.
It is always recommended to select the Live Nesting while attaching any reference.
