| Product(s): | ProConcrete | ||
| Area: | Settings | ||
| Subarea: | N/A | ||
In this wiki, we will see how to change the naming conventions for ProConcrete Elements and color values of rebars as well.
Users are aware about the ProSteel Options. But this wiki will guide you about ProConcrete options.
1. To find the ProConcrete options, navigate to the backstage File>settings>user>PC options from drawing.
2. The dialog box for ProConcrete options will open.
3. In this dialog box, under concrete tab, you can change the style of naming conventions of the Concrete elements. You can define the conventions as per your requirement.
4. Under the color option, you can define the color of rebar elements and different rebar conditions.
In this way you can control these element properties from the ProConcrete options.
