| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Data/Reporting |
| Subarea: | N/A |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
Hoe to reset the Bar Factory Settings and enable the Shape Definition File re-selection ?
1) Enter the key-in proconcrete delete barmarks
2) Now, select the second option, that is Delete bar marks and reset bar factory settings
3) The previously input Bar Factory Settings will then be cleared and available for editing
