| Product(s): | Power ProStructure | ||
| Version(s): | V8i (version number) | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author | Sandip Kar, Bentley Product Advantage Group |
There are some hidden commands which can only be run through Utilities > Key-in.
Among these "mdl command PC_MANAGE_RSF" is the one to manage the Shape Definition file.
Run the key-in command "mdl command PC_MANAGE_RSF" . The system will open the Shape management dialog box. Then you can browse the .rsf file which you want to update or manage.
If you have refreshed or changed the code please use
Please Key-in
proconcrete manage refreshcodes
