| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Drawing Production |
| Subarea: | 2D Rebar Modification |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
The Arrow Label will allow the Main and Longitudinal bars to be labeled while detailing. The Arrow Label used for Section detailing is also available for bar ranges.
1) Set up the label text as required and then click on the New button to add the label. Choose the label type as Arrow Label
2) In the drawing model space, a prompt is displayed asking you to indicate of the start point of the label
3) When a data point is selected, the program uses its auto-snapping facility to automatically attach the label line to the nearest point on the main bar
4) Continue selecting data points until all label lines are located (up to an allowable maximum of four)
5) Select the Reset button when all lines are located
6) The label text then appears, extended from the last label line
communities.bentley.com/.../how-to-add-custom-rebar-annotation-labels-as-presets
