| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Drawing Production |
| Subarea: | 2D Rebar Modification |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
The Bar End Details will allow you to modify the 2D rebar ends to be displayed as ticked ends or with tags
1) The Ticked Ends option will allow to set a tick at one end of the 2D rebar
2) The Reverse Tick option will change the tick to the opposite direction
3) The Tagged End option will allow to attach tags to the ticks at rebar ends
4) To set up the bar end details on the other rebar end, click on the Next End button. This will select the other end of the 2D rebar
communities.bentley.com/.../how-to-display-rebar-ends-as-ticked-and-tagged
