| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Drawing Production |
| Subarea: | 2D Rebar Modification |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
Bar Label Attributes can be modified at any stage during the detailing process, thereby allowing you to override their current ‘default’ parameters of the rebar labels / annotations. Although all new bars always start with the same initial Bar Label Defaults, they might eventually be saved with completely different Bar Label Attributes
These attributes can only be changed while placing or modifying a bar
1) The Color, Weight and Justification options will allow you to set the color of the label along with the line-weight and position
2) To enable the Height and Font options, set the Text Style as ‘None’. You can then set up the font and its size as per requirement
