| Product(s): | ProConcrete | ||
| Area: | ProConcrete Utilities | ||
| Subarea: | Rebar Utilities | ||
This section contains the wikis related to the ProConcrete Codes Manager tool in ProConcrete CONNECT Edition. This tool is used to specify code units and select the current concrete code and can be accessed under the Concrete workflow > Utilities > Rebar Utilities > Rebar/Concrete Codes.
