| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Drawing Production |
| Subarea: | 2D Rebar Modification |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
Several bar range display options are available within the ‘Bar Range Display’ tool box
This document will guide you on how to set up the different 2D bar range display options in the drawing model
1) The ‘Detail All Bars’ option shows all bars in range. Instead of showing just one of the bars in a range, you can detail all bars throughout the range when this option is checked
2) The ‘Hide Delimiters’ hides the delimiters between individual bars if the detail bars option is selected or between start and end of range if option for Detail All Bars is turned off
If delimiter lines for the current range are not required, select Hide Delimiters
NOTE - Care should be taken when turning delimiters off. Existing bar labels may have been extended from these delimiters
3) The ‘Dual’ option will show dual bars in the range. You can detail all dual bars throughout the range when this option is checked
This option will work for the Dual Type Delimiters only
4) Use this option to show all radial bars in range. You can detail all radial bars throughout the range when this option is checked
5) The ‘Offset’ buttons can be used to increase or decrease the spacing between the initial bar location and reference concrete face
In this way, one can set up the range display for 2D rebars in the drawing model for reinforced concrete detailing
