Product(s): | Bentley sisIMS | ||
Version(s): | 08.11.07.121 | ||
Environment: | Windows 7 64 bit | ||
Area: | General | ||
Subarea: | N\A |
The installation of Microsoft Security Update KB3032359 (for InternetExplorer 11) can cause the Objectinfotab in the Infocenter leaves blank.
This can be solved by installing sisIMS 08.11.07.125 or higher. Besides many other advantages and new functionalites this version doesn't need the Adobe-SVG-PlugIn! Therefore it also runs with other popular broswers like IE11, Firefox and Chrome (If SAP connection is required only IE11 can be used).
Original Author: | Andreas Becker |
