| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Drawing Production |
| Subarea: | 2D Rebar Modification |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
The Delimiter Label is the second of the label types applicable only to bar range details. It is selected from the third icon in the Type icon tool box
This label type extends a straight line from the end of a selected delimiter line
1) Set up the label text as required and then click on the New button to add the label. Choose the label type as Delimiter Label
2) As soon as the option is activated, you are prompted to "Indicate end of delimiter for start of label"
3) A data point should be indicated in close proximity to the delimiter from which the label is to be extended.
4) The command auto-snaps to the closest delimiter end and begins dynamically to adjust the end of the first label line
5) The system then awaits indication of a second data point defining the end of the first label line
6) Note the first label line is always extended outwards from the chosen delimiter, even though the data point may be indicated between the delimiter ends
7) The label text then appears in-line with the delimiter line
