| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Drawing Production |
| Subarea: | 2D Rebar Modification |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
The Line Label will allow the Main and Longitudinal bars to be labeled while detailing. The Line Label used for Section detailing is available for bar ranges.
1) Set up the label text as required and then click on the New button to add the label. Choose the label type as Line Label
2) In the drawing model space, a prompt is displayed asking you to indicate the location of the text along the delimiter line
3) When a data point is selected, the program uses its auto-snapping facility to automatically attach the label line to the nearest point on delimiter extension line
4) Select the Reset (right click) button once the label is placed
5) The label text then appears in-line with the delimiter line
