| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Drawing production |
| Subarea: | Detailing |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
This document will explain the process to copy an existing bar label format set up for a 2D rebar to another 2D rebar in the drawing model for adding Bar labels quickly while detailing your drawings
1) In the ‘Drawing Production’ tab, click on the ‘Quick Edit’ tool
2) In the ‘Quick Editing’ toolbox, choose the ‘Copy Bar Label’ option
3) Now, click on the ‘Edit selected bar’ button and choose the label which you want to copy (source label)
4) Then select the rebar for which you want this label applied (destination label)
In this way, one can use the ‘Copy Bar Label’ tool to quickly add labels to the 2D rebars in your drawing model for detailing
communities.bentley.com/.../how-to-add-custom-rebar-annotation-labels-as-presets
