| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Drawing Production |
| Subarea: | Detailing |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
This document will explain the process to quickly create or replace a bar label for 2D rebars in the drawing model
1) In the ‘Drawing Production’ tab, click on the ‘Quick Edit’ tool
2) In the ‘Quick Editing’ toolbox, choose the ‘Bar Label’ option
3) Now, click on the ‘Edit selected bar’ button and choose the 2D rebar for which you want to place a new label OR replace an existing label
4) Now in the ‘Quick Edit Label’ dialog, type in a new syntax for the label and then left click to accept
In this way, one can either create new labels OR modify existing labels (in part / full) for 2D rebars in drawing model with detailing
communities.bentley.com/.../how-to-add-custom-rebar-annotation-labels-as-presets
