| Product(s): | ProSteel | ||
| Version(s): | All | ||
| Area: | ProStructures | ||
| Subarea: | N/A | ||
| Original Author: | Detlef.Hackbarth, Bentley Technical Support Group | ||
| Updated By: | Vyanktesh Nama, Bentley Product Advantage Group |
With ProSteel software you can efficiently create accurate 3D models for structural steel, metal work, and steel assemblies. You can then quickly generate design drawings, fabrication details, and schedules that automatically update whenever the 3D model changes. Additionally, detailed output to CNC machines automates the steel fabrication process.
ProSteel fully supports your construction and planning tasks for structural steel and metal work in a 3D modeling environment. Working with AutoCAD or MicroStation, you get an intuitive and integrated multi-material modeler perfectly suited to layout complex structures, produce shop drawings, assemble all your connections, and manage your bills of materials.
Prosteel Connect Edition: Detail Anything, Fabricate Everything
