| Version(s): | through 08.11.13.73 | ||
| Area: | Component Features | ||
| Subarea: | Symbol on the Fly |
After using the Symbol On The Fly tool to insert a box symbol onto a page, how can the size of the box be changed?
Right-click the Symbol On The Fly box on the page.
Select Symbol Settings from the pop-up
In the Scale area of the Symbol Settings dialog, set the Horizontal value to the desired width and set the Vertical value to the desired height.
Click OK.
Since the connection points of a Symbol On The Fly are intended to fall within the border of the box, it is recommended to delete and re-insert connection points that are outside the box after the resizing operation.
| Original Author: | Matt_P |
