| ID | Title | Area |
| 667040 | Merge Into Master is now working in all cases | General Fix |
| 679224 | ProStructures options are using levels from dgnlib and design file | General Fix |
| 680433 | A user configuration variable was introduced to enable or disable the dwg adopter | General Fix |
| 682398 | Support for RealDwg2022 | General Fix |
| 706025 | Improved Bently Automation Services for ProStructures | General Fix |
| 767683 | Dgnlib files for text styles and levels have been added | General Fix |
| 775763 | Improved configuration audit alert message | General Fix |
| 785900 | Extended ISM Export support for Concrete shapes | Interoprability |
| 667007 | Wall and slab RebarSet always updated in all scenarios | Concrete and Rebar |
| 667060 | RSF file for Swedish standard | Concrete and Rebar |
| 667124 | Corrected polycut RebarSet end condition rotation for multi leg Irregular dispatch and Single Rebar Distribution | Concrete and Rebar |
| 683638 | Dynamic views 2D rebar resymbolized levels are now synchronized with the properties of the 3D model rebar levels | Concrete and Rebar |
| 686048 | Applied default color of rebar after using Lap/Splice Rebar modification tool on rebars | Concrete and Rebar |
| 687650 | Perimeter and Opening trimmer now gets back to the default color from white color | Concrete and Rebar |
| 690459 | Footing Reinforcing clone tool is working in continuation in the case of Column Reinforcing Tool | Concrete and Rebar |
| 690460 | Pad Footing tool can be used recurring with the save button | Concrete and Rebar |
| 690462 | Edit End Condition tool correctly applied even after cancelling the macro | Concrete and Rebar |
| 690463 | Use reset to exit from Modify Rebar tool | Concrete and Rebar |
| 691920 | Rebars with locked levels are prevented from Rebar Modification tools | Concrete and Rebar |
| 693106 | Improved delimiters for skewed for rebar with end condition | Concrete and Rebar |
| 699833 | Strip footing rebar now placing correctly while placing on multi segment footing with insertion point other than middle | Concrete and Rebar |
| 700081 | Transverse Rebars are now treated as alternate rebar for close buttom rebar | Concrete and Rebar |
| 700094 | Impoved placement of circular template ties | Concrete and Rebar |
| 702519 | U-Bar 2D representation is corrected in section views | Concrete and Rebar |
| 706280 | End condition impoved after adding laps to the Rebars | Concrete and Rebar |
| 708770 | When using level attributes tools it's possibel to change 2D rebar levels | Concrete and Rebar |
| 709383 | Upon selection of rebar it's belonging concrete element is highlighted | Concrete and Rebar |
| 714975 | Performance fixes for rebar SDK | Concrete and Rebar |
| 716169 | Rebar label FDOT variable is now working when it's set to 0 | Concrete and Rebar |
| 722224 | CRR,CSR & Rebar attached to referenced solid or concrete element is now updating to the new location when reference is been moved | Concrete and Rebar |
| 724736 | Rebar are getting selected as whole assembly or RebarSet after reopening the dgn file | Concrete and Rebar |
| 733701 | Start and End rotation is now independent for Ties in Column Reinforcing | Concrete and Rebar |
| 737107 | FBRM tools are working with elements from OpenTunnel designer | Concrete and Rebar |
| 738184 | Main bar label can not be moved in all circumstances. | Concrete and Rebar |
| 742247 | External Angle value is now correct in all cases for V shaped bars | Concrete and Rebar |
| 744317 | Improvements in Rebar shapes detection | Concrete and Rebar |
| 744697 | Correct position of End Preparations in the Schedule Generator | Concrete and Rebar |
| 744699 | Correct Pin Diameters in ARMA export | Concrete and Rebar |
| 744732 | Correct Pin Diameter in Schedule Generator | Concrete and Rebar |
| 744736 | Corrected angle value display with the Swedish Rebar Shape code | Concrete and Rebar |
| 745744 | ProConcrete recognizes all managed rebar shapes which are bent in two planes (H & K dimension issue) | Concrete and Rebar |
| 745777 | Concrete & Rebar quantity in the Schedule Generator for copied rebar elements is correct | Concrete and Rebar |
| 747730 | Corrected a crash while placing section callout for inclined wall rebarsets | Concrete and Rebar |
| 762264 | All RebarSets are moving along with concrete while using MS Move | Concrete and Rebar |
| 776313 | Performance improvement with Long bar Fudge | Concrete and Rebar |
| 778913 | Multi plane rebar are getting managed in first execution | Concrete and Rebar |
| 695746 | Correct radius dimension with turned on 'Associative Dimensioning' | Detail Center |
| 724097 | 3D modeling environment manual cut is now working in all cases | Detail Center |
| 677207 | Welded shapes with different length and modifications getting correct position numbers | Steel |
| 702606 | Purlin fly brace UI issues have been fixed | Steel |
| 703102 | Shape databases are all listed if ProStructures is installed on non default path | Steel |
| 711385 | Shapes are getting placed properly on a user defined ACS now | Steel |
| 711925 | Modifying Single Holes leading to a crash is fixed | Steel |
| 714184 | Material manager is improved | Steel |
| 715838 | In ShearPlate connection, Stiffeners are now switching between front and back side of supporting member after changing the shearplate position | Steel |
| 771275 | ProStructures is now stable while placing ShearPlate connection in a somewhat specific orientation | Steel |
| 773396 | Fixed Copy\Move assembly function of purlin fly-brace connection | Steel |
