| Product(s): | ProSteel | ||
| Area: | Data/Reporting | ||
| Subarea: | N/A | ||
In this wiki, we will learn how to change the Group and assembly prefixes in the In drawing partlist.
1. Double click on the placed In drawing partlist and this will open Drawing Partlist dialog.
2. Now, under the ‘Layout’ tab, select the style which you are going to user and then click on the edit current style button which will open the format dialog box.
3. In format dialog box, go to the edit footnotes of the partlist option.
4. Here, at the bottom you can change and control the Group, subgroup and assembly prefixes which will be displayed in the drawing partlist.
