| Product(s): | ProSteel | ||
| Area: | Data/Reporting | ||
| Subarea: | In-Drawing Partlist | ||
In this wiki, we will learn how to set the fraction type as ‘Diagonally Stacked’ for imperial units in the Bill of Material (In-Drawing Partlists)
Refer to the image below for a better understanding.
Note: This feature is introduced in the ProStructures CONNECT Edition Update 6. So, users using the older versions will not see this option for applying Diagonal Stacking.
1. Create an In-Drawing partlist for the elements in the model. If the partlist (Bill of Material) is already created, then double click on it.
2. This will open the Drawing Partlist dialog and under the Insert tab, select the desired Partlist Style and click on the ‘Edit Partlist Style’ button.
3. In the Edit dialog box, navigate to the ‘Text’ section and set the fraction type as ‘Diagonal Stacking. Once done, click OK.
4. This will set the Fraction Type as Diagonal Stacking for imperial units.
