| Product(s): | ProStructures CONNECT Edition | ||
| Area: | Help File | ||
| Subarea: | Help | ||
| Original Author | Sandip Kar, Bentley Product Advantage Group |
This document will explain the different way to access help documentation of ProStructures.
You can get access ProStructures Help via following options.
(A) Through CONNECTION Client
1. When opened the CONNECTION Client, click the Connection center.
2. This will lead you to CONNECT Center and will open the page https://connect.bentley.com/
3. This will open up the Documentation page and from there select Structural detailing section and click on the links of different help documents.
(B) Through the Application itself.
1. When you launch ProStructures and open any DGN file, at the right upper corner there is one Help Button. By vclicking on that button, it will redirect to documentation page https://docs.bentley.com/
2. This can also be access when you go to backstage, File > Help > Help Contents
(C) Through the Bentley Web Page
You can visit the Bentley web page at www.connect.bentley.com.
From here on you can follow the same steps mentioned in Option - 1 from Step 1 to 2
