| Product(s): | ProConcrete | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Sandip Kar, Bentley Product Advantage Group | ||
| Updated By: | Vyanktesh Nama, Bentley Product Advantage Group |
ProConcrete CONNECT Edition is a reinforced concrete modeling and detailing software. With ProConcrete software you can model reinforced concrete with any combination of reinforcing, as 3D parametric objects. Quickly create your placing drawings, fabrication details, bar bending schedules, and concrete quantity and material reports directly from your 3D model, which automatically updates to reflect model changes. You can reduce documentation production time, errors, and design flaws with our advanced 3D application for modeling, detailing, and scheduling of reinforced in situ/precast and post-tensioned concrete structures. With simple and easy-to-use tools for advanced 3D modeling of reinforced concrete structures you can:
www.bentley.com/.../proconcrete
Following video describes the complete ProConcrete workflow for a Reinforced Concrete Structures Detailing, from Modeling to Documentation.
This main sections contains sub sections where one can find the topic-wise wikis related to ProConcrete CONNECT Edition.
