| Product(s): | ProStructures |
| Area: | General |
| Subarea: | Preferences |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
ProStructures tags are elements that may be attached to elements drawn in designs. For example, a cell might have an attached tag that includes a name or number for the cell. Tags are similar to AutoCAD attributes, which are more constrained.
This Wiki will guide you on how to invoke the Tag tools to work with in the ProStructures CONNECT Edition.
1) Open to ‘Tool Boxes’ dialog box by clicking on [CTRL + T] and then click on the checkbox for ‘Tags’
2) Then click on OK. After this, you will be able to use the ‘Tag’ tools form the ‘Tags’ toolbox.
For more information, you can refer the Help pages for Tags in ProStructures
docs.bentley.com/.../GUID-3844B57C-652F-9255-2212-DD45F4DD1B1F.html
