| Product(s): | Bentley Substation | ||
| Version(s): | through 08.11.13.140 | ||
| Area: | PowerPlatform Support | ||
| Subarea: | N\A |
How can I import a .LAS file?
A .LAS file is a LiDAR file. These files need to be converted to POD format so it can be attached. Use the point cloud tools are platform tools so they are documented in the [[MicroStation Help file]].
This should result in the point cloud being attached to the DGN and displaying in the view selected in the Point Clouds dialog.
