| Product(s): | ProSteel | ||
| Area: | External Partlist | ||
| Subarea: | ProStructures Partlist dialog | ||
This section contains the wikis related to the ProStructures Partlist dialog of ProSteel CONNECT Edition. This tool used to generate and create the output of a parts list and can be accessed under the Steel workflow > Data/Reporting > Reporting > Create ProSteel Partlist.
Key-in: PROSTRUCTURE LOAD PARTLIST
