| Version(s): | 08.11.xx.xx | ||
| Area: | Component Management | ||
| Subarea: | Parts Database |
When trying to add or modify a part number on the Parts Database Manager dialog, the following error occurs.
Internal Error
Error Message: Object reference not set to an instance of an object.
TargetSite: Void CheckField()
DeclaringType: Bentley.Electrical.UI.PartsDatabase.DEditPartsDatabase
Attributes: private
MemberType: Method
| Original Author: | Matt_P |
