| Product(s): | ProSteel | ||
| Area: | Steel Placement | ||
| Subarea: | Shape Layout | ||
| Original Author: |
Detlef Hackbarth, Bentley Technical Support Group | ||
| Updated By: |
Vyanktesh Nama, Bentley Product Advantage Group |
In some cases you may observe a Standard Shape, UserShape (self-created shape) or any shape is not displayed the way you expect it to be.
The contour of the shape is incorrect; sharp edges instead of rounded corners are displayed.
1. Open the PS Properties of the shape by double clicking on it or by holding right click and selecting PS Properties.
2. Go to the General Data > Layout, in this page change the layout to Edges Outside or With Arcs to get the supposed result.
a. Shape Layout with "Edges Outside"-
b. Shape Layout with "With Arcs"-
Steel Placements & Elements - ProSteel CONNECT Edition
