| Product(s): | ProSteel | ||
| Area: | Detail Style | ||
| Subarea: | General | ||
Object lines are not visible in the detail center preview or in the detail output. The dimension and annotations are visible.
This issue is very random and not reproducible in another machine. Hence, it is difficult conclude that in which case this issue is appearing.
Please try the below methods to solve this issue sequentially.
1. Restart your software.
2. Assign different detail styles to your parts.
3. Try to open your file in a different workspace and check this.
4. Delete the details blocks from the Insert tab of Detail Center.
5. Reset all from the Service Function in the details center.
5. Clear the user preferences and try again with the same workspace or another workspace.
6. Restore the software to it's default factory settings.
Wiki: How to restore the default factory setting for ProStructures CONNECT Edition?
7. The last thing you need to do is to re-install the ProStructures application.
a. Please uninstall the ProStructures application first.
b. Then delete all the ProStructures related files and folders that are created by default and does not get deleted by simply uninstalling the application.
For more information on this, please follow the below wiki link:
ProStructures not working even after re-install
