| Item Number | Description |
| 797711 | Component center workflow improvements |
| 934592 | Added button assignment "SHIFT+RESET" Drawing View tool |
| 934785 | Added button assignment "SHIFT+TENTATIVE" Drawing Aids Snaps tool |
| 866777 | Fixed issue with the partlist style duplicate entries |
| 958186 | Upgrade version iTwin Structural Synchronizer and using now 12.02.00.139 |
| 907011 | Improved IFC export for the shapes placed on complex chain |
| 915673 | Fixed Length calculations for mirrored shapes after modifications |
| 798985 | Fixed the ProStructures crash while adding holes in a bend plate that has 4 flanges |
| 903376 | Fixed the ProStructures crash While changing near side or far side in stiffener |
| 785905 | Fixed the ProStructures crash of 'Search Groups from given Position numbers' |
| 862248 | Improved PartFamilies assignment for the shape placement using two point method |
| 764198 | The Baseplate General Re-apply connection button in now fully visible |
| 671945 | Free Ends of bar are automatically ticked even when EDF1 and EDF2 variables in display sys set to 1 |
| 724711 | Improved data integrity of RebarSet using 'Save-As' |
| 726807 | Improved behavior of rebar added to parametric cell using Irregular Dispatch with associative face based rebar tool |
| 727380 | Improved behavior of rebar added to parametric cell using single rebar distribution with associative face based rebar tool |
| 734728 | Concrete Net Volume is included in Partlist Database |
| 766230 | Shape codes have the correct assignment to rebars in VarySet |
| 774223 | Improved move and copy command in 'Rebar Tools' |
| 776772 | Single Rebar Distribution is included in Bar Analytics |
