| Area: | MicroStation Basics | ||
| Subarea: | Manipulation Tools | ||
| Original Author: | Roger Belen, Bentley Product Advantage Group | ||
| Updated By: | Vyanktesh Nama, Bentley Product Advantage Group |
When modifying the ProStructures Elements the Grips/Handles are not visible.
In the Element Selection dialog, make sure that the Handles are not disabled (the button should be turned off).
