| Area: | MicroStation Basics CONNECT Edition | ||
| Subarea: | Explorer | ||
Let’s say you have hundreds of drawings to review and don’t want to open them one by one each time in a new session of the ProSteel application then this wiki will help you to review them without wasting much time in a single ProSteel session.
1. Open one drawing in the ProSteel application from the folder which has many drawings in it.
2. Under the Steel workflow, navigate and left click on the Explorer button located at Home > Common Tools > Explorer.
3. In the Explorer dialog, navigate to Links > Active Directory > Designs here you will find all your drawings.
4. Now, you can review one by one drawing in a single session without wasting much time.
In this way, we can review many drawings at one place in the Explorer dialog.
