Product(s): | Promis.e, Bentley Substation | ||
Version(s): | through 08.11.12.137 | ||
Environment: | N/A | ||
Area: | Component Features | ||
Subarea: | Insert Symbol By Name |
When trying to insert a symbol onto a project page, the following error messages occur:
Information
Invalid Cell Library: [path]\[symbol name].Dgn
Incorrect symbol
The symbol format is incorrect, please refresh the catalog and try again.
These messages have occurred when the user had insufficient permissions to the catalog folder or DGN file for the symbol. The situation can be reproduced by denying read permissions to the DGN file.
A test for this situation would be to try to open the DGN file specified in the error message using File > Open. The user with insufficient permissions received this message when doing so:
Alert
You do not have access permissions to open file [path]\[symbol name].Dgn
Grant necessary file/folder permissions to the user. The user should have at least Read permission on the DGN files and the catalog.mdb file. When the catalog is shared with multiple users, each user must have "read, write, and create rights for the folder in which the database is located," per Microsoft, or else other error messages can occur (see the [[Error - .MDB file in use or locked by another user]] article).
Original Author: | Matt_P |
Keywords: copy, right, privilege
P/S: 78571, 500000093118
