| Area: | General | ||
| Subarea: | Properties | ||
When we try to see the MicroStation Properties of ProStructures elements there so many types of properties visible in the dialog box.
As there are so many types of properties visible, we can limit the number of properties visible.
In this wiki, we will learn how to hide unnecessary properties.
1.Right Click on any ProStructures’ element and click on its Properties.
2. This will open the properties dialog showing all the properties like geometrical properties, structural properties etc.
3. To hide any individual property, right click on the section of that properties and click on hide option.
4. This will show ‘Show/Hide’ option and from here you can uncheck the properties which are not useful for you.
In this way, you can limit the number of properties which as per the requirement.
