| Version(s): | through 08.11.13.140 | ||
| Area: | Component Management | ||
| Subarea: | Parts Database |
Why are the changes I made to the parts database not appearing in my project? Old, incorrect, or missing part number related information is seen in reports, on Insert Symbol By Device ID, Run Graphical Plan, or elsewhere in the project.
When a part number is assigned to a device in a project, the record for that part number is copied from the parts database to the project database and linked to that project. The same part number will have a unique record in the project database for each project in which it is used.
When a part number record is modified in the parts database, the part number information is not automatically updated in the project database by default. This is intentional behavior - it preserves the part number information in a project so the information in completed projects appears as designed.
To update a project with changes made to the parts database:
Items that are not dynamically updated by the software, such as reports (including Text On Drawing) and graphical plans, will need to be deleted and generated again.
Introduced in promis.e V8i SELECTseries 5 (08.11.10.xx), there is a setting to control what happens after changing a part number record using Parts Database Manager. Select Options > System Options > Update Part Number to choose one of the following options:
| Original Author: | Matt_P |
Keywords: bill of materials, BOM, Insert Symbol, price, missing, wrong, incorrect, obsolete, part number, does not match, Run Graphical Plan
